gsxitement
- 1,967
- 1,944
- Dec 9, 2002
DOBBS FERRY,
New York
So the motor in my Time Attack car has been doing great. I built it in 2018, and hasn’t missed a beat the entire time.
I ended my season early cause I have a lot of stuff to catch up with as far as racecar, truck, house etc. Before I start tearing the trans out for a rebuild, I wanted to check the vitals on the motor. So far just a compression test. Numbers are as follows: 130/130/150/150.
I’m going to do a leak down test when I get a compressor over to the house, and check crank endplay. I have the Magnus rebuildable oil filter, so will obvs pull that apart to see what’s happening.
My question is, based on those compression numbers, would you send the motor next season? Or pull it all apart and see what’s going on in there? Blow by is minimal.
