tsiunderpsi
- 0
- Aug 20, 2005
Sandpoint,
Idaho
Hey All,
Looking to purchase a replacement motor for my recently discovered crank walking issue.
I'm planning to go check out a 6 bolt long block from a local dsmer. I've never had to do this before so what are some critical factors I need to be aware of before handing over my hard earned $ ? From what I can tell he has a decent reputation with the local forum. Asking $ for the long block is $500.
The long block has been removed from the car it was in and is currently sitting in this persons garage. I plan to pull the oil pan and inspect the bearing, crank and rods for wear and attempt a leak down test. What else should I be on the look out for?
What would be some red flags that would cause you to walk away from buying a used motor?
Thanks in Advance!
Thanks in Advance!
