Timing tensioner pulley question
cj062989
56
May 20, 2009
North, New Jersey
So I did the timing on my friends car and after I turned, torque and Tensioned the tensioner pulley, the orientation of the two holes on our eccentric tensioner was positioned at "11 and 1"....
My question is if it in the right location or is it too tight?????????????
You have to use the granade pin as a refrence, it has to be able to be put in and pulled out easily then you know it's at the correct tension. The orentation of the holes doesnt matter as much.
I agree. This is where my holes ended up with proper tension and was able to pull and reinstall the grenade pin.
Pulley holes shouldn't be used as reference. Get a feeler gauge and check the clearance between auto tensioner and the tensioner arm is .15-.18 inches.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
