1G Timing jumped
Wildwomper
Mar 31, 2018
Houston, Texas
Long story short, my friend was cleaning oil off of my valve cover while the car was running and the paper towel got sucked into the timing belt. We turned the car off ASAP, got as much towel out as we could and the idle sounded off so I turned the crank until all the timing marks lined up and the cam marks are spot on but the crank is at about 20-25 degrees before tdc. Is this enough offset for the timing to allow valve collision? I don’t remember hearing any crunching or smacking noise at the point when the towel got sucked in but the idle is just sporadic now. Is this enough off timing for valves to get bent? All this after I just got done replacing everything because of a snapped timing belt. It still feels like compression is good when I turned the crank by hand. But I just need some other opinions. Thanks a lot guys.
Why were you running it without a timing belt cover???
Because I literally just got finished putting everything back together and wanted to run it and check for belt slap to make sure I tensioned everything properly. I know I should have put it back on. But do you think it actually slapped some valves by jumping only 25*?
Keep rotating the engine, you may be on a different stroke. Rotate it again to confirm tdc and see how it looks
Set to tdc. Check cams relative to that. Not the other way around. Then you can reset timing at this point. Do what I said and you'll know how far off you are. After it's back in time you can do a leakdown. The 25 degrees you mention isnt relavent if you're talking about how far crank is off when cams are in time. They dont turn at the same rate. You check cams relative to crank so set crank first. My guess is both cams are off 3 teeth or less. From my experience you got a 50 50 shot. Leakdown after you fix it will tell you.
Alright everyone, I appreciate everyone’s input. The car is perfectly fine. Still has the same power as it did before and no ticking from bent valves. Runs smoother than ever. Thank god.
I would not trust no ticking meaning no damage. I would do a leakdown anyway. It's probably fine but peace of mind is better. Visual inspection through the spark plug hole tells a story also
Yeah I plan to rent a compression tester tonight from the 24hr auto zone and get that done tonight. I did some tuning last night and everything checked out. I did some runs with my friends speed three and on the last one the idle started to break up after the pull. But it returned to normal. I think my plugs or ignition system may be on its way out. I did get some knock also. But that’s perusual until I upgrade my injectors. Those are coming this week also.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
