timing belt help
Hitmachine101
352
Nov 16, 2009
Rochester NY, New York
hey guy starting on my project of re timing a motor the PO couldnt get timed ( 95 gst )
i striped the timing belt off and am starting from the basics ( the car was sitting for over a year and a half ) --
my question is should the oil pump be really hard to turn? i was under the impression that it should spin pretty freely and not be hard enough to turn that i have to put a ratchet on it and put some good force behind it to spin it
do i have a problem here or is this normal?
thanks in advance
I recently retimed my buddys 96 gst and for sure i remember that it didnt take much to spin the oil pump to align the timing marks.. only the crank took some force of course. If i were you id do the good old fashion water pump, oil pump, tensioner, and of course oem belt replacement. Especially since its been sitting for that long, you dont want to just slap things back together and risk head problems. Better to be safe than sorry especially with dsm's
ok sounds like that things toast, i timed the motor and its all timed correctly, im getting
45,0,0,0 across the board for my compression -- sounds like bent valves to me -- what do you guys think?
re do the head, new oil pump, water pump, and timing belt in order it sounds liek
the cars timing was probaly off alot and you bent some valves.. and just to make sure i would do a leak down test to make sure you're rings arent worn out as well. dsmgraveyard has 2G heads new and used that you could slap on to get her running again
and yes absolutely change the water and oil pumps, and timing belt
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
