SrKegler
- 1,123
- 37
- Feb 29, 2004
Daytona Beach,
Florida
I just finished changing the water pump. Replaced the timing components. Everything was lined up, and stayed lined up after rotating the engine 6 turns.
Left on a trip, went 300 miles with two stops along the way. Car ran perfect. Started the car up to move it and heard an awful rattle under the hood. Parked it. Next morning started it up to do some trouble shooting, had what sounded like lifter tick. Let the car idle up to operating temp, noise quited down some. Shut it off and went into town for some seafoam.
Car now won't start, sounds like the timing is off. Cam gears line up perfect, just can't get the crank sprocket to line up.
What has me puzzled is why it ran so good, then all of a sudden jump time. No damaged teeth that we can see on the belt.
Tomorrow I plan on pulling the front cover off and checking things out.
Anyone else had this problem, any suggestions. I'm now 300 miles from home and need to get it back in service.
