420A Timing adjustment
Madmackin942
4
Jan 13, 2018
Gulfport, Mississippi
Was half tooth, last week,uncovered it lined everything up again now it a full tooth off, did my belt stretch,was told by shop let it sit,but the stretch is at top of cams
And it's the gates blue rpm belt
Did you check the alignment again after tensioning the belt last week? A lot of times it looks like it's aligned until you tension the belt.
The belt shouldn't stretch so much that it throws your timing out of alignment by any appreciable amount. Since you have adjustable cam gears, though, it's possible that one or both gears slipped.
That timing is definitely a tooth off.
Loosen the tensioner and set it again. Looks like the exhaust cam needs to be turned clockwise a tooth. But you need to center up both cam gears.
