JT Power
- 30
- 0
- Oct 15, 2007
sutherlin,
Oregon
I need to adjust my valves. Does anyone know what the specs are to adjust them.
Did some shop tell you that? If so have them do it and then SUE 'EMI need to adjust my valves.
. Explain to your friend that hydraulic lifters run zero lash, and give a look to "lifter tick" in the Search here.My friend does a lot of mechanical work, and has never seen them that tight.
He thinks, that them being to tight its making them rub a little to hard, and can see it's made them worn more then they should.
I wanted to adjust them because, they are making unwated noise.
