Tial w/ stock mas ans DSMLINK
suprdave09
42
Sep 19, 2004
Troy, Michigan
Is there anyway to compensate for extra fuel after shifts with dsmlink so that i dont have to go back to the translator.
None that will work as well as correctly recicurculating. Since you shift at different RPM points, it not like you can lean out settings for each gear. Either put the MAFT back on or recirculate.
Sorry,
Andy
I understand that you can't recirculate a Tial BOV. You'll either need to change it out for something that will or run the MAFT.
Or you can wait for the new version of DSMLink, supposed to have the ability to replace the MAFT, only problem is they are doing the new 2g version first before the 1g & still don't know when the new 2g version will actually be released. So pretty much what Andy said :D
