LKWTSI
- 601
- 10
- Feb 7, 2008
Lake Wylie,
South Carolina
After searching for the answer, it doesn't look like this is a very common done fix, so I'll ask the question if someone knows different I'd appreciate a response.
After a boost leak test, I discovered my #3 injector insulator was leaking and the BISS. I replaced all the insulators and the BISS O ring. They sealed up nicely, but now I have a leak at the TB shaft. Most obvious is the TPS side and I took the TPS off and RTV'd the flat rubber gasket and the TPS body to TB face. Still leaks and it sounds like the other side with the Throttle cable return spring is attached.
So my question is can this seal be replaced or do I have to find a new TB. I did the test to about 20PSI and it leaks down so quick it'll not hold any pressure.
Thanks.
Thanks.
