Balance shaft oil seal
GSXtra
51
Aug 31, 2012
St.Charles, Iowa
I am looking to buy the oil pump seal that is found on the outside of the oil pump at the end of the rear balance shaft. I cannot figure out how I am suppos to seal that up and I have looked but cannot find the part I am looking for. Any help would be great
that video is great, but im way past that point. what I am looking for is a OEm oil seal. I have my race balance shaft on but when bolting it back to the oil pump housing I know there is suppos to be a seal on the outside of the housing so oil doesnt leak out. That is the part I am looking for. I think I needed to use the original part but I got the engine in pieces and can not find that outer seal to insure I dont have an oil leak when I try to start the engine. I am looking for a part # and a place I can purchase the bolt and seal
i am looking for the bolt that goes in this spot. does it need to be a banjo bolt or just a normal bolt. also there has to be a seal there I think but I do already have the oring that was already mentioned. basically I am just wondering if I need a special bolt/ washer to hold the balance shaft into the oil pump. Also, I have a stubby balance shaft that was made from and original balance shaft so my question is also is do I need to plug the hole that would be feeding the rear balance shaft bearing?
