throttle body removal
Icyu11725
63
Jan 25, 2012
northport, New York
Im trying to replace the gaskets between the throttle body and the elbow, and the gasket between the tb and the intake manifold. I took out the 4 bolts in each corner of the tb. But i cant get the tb to come off. any advice or mayb something i missed? it just wont budge.
yes the upper pipe is removed because i took the elbow off already and throttle cable is off
here are some pictures of what i did
Give it a good pop like everyone said, it's just stuck on the gasket.
i can literally grab the tb and yank it and move the cars suspension without it budging LOL
damn. This may not sound pretty but, try Banging a flat head in different spots into the side closest to the intake mani, wiggle and finesse with it until you can get it loose(with the screw driver)
i used a screw driver and hammer tht didnt work. soci took the hammer and smacked it and it came off LOLl. thank you guys
Remove the throttle cable and the 2 coolant lines running to the bottom of the TB. If everything is removed try tapping it gently with a rubber mallet. Someone may have used RTV before to make a seal.
Too slow.
