4gfun
Supporting VIP
- 2,009
- 56
- Dec 10, 2007
Ask Me,
Virginia
My throttle body was leaking during the boost leak test, so I decided that I should just take it off and investigate. I did a search on the combined boost leak thread but it takes me about 3 hours to go through it properly. (I tried it the other night).
I would like to know every gasket/o-ring for this throttle body and where I can get the parts from. (I prefer to get them online rather than locally).
I also found 2 seperate throttle body shaft replacement links but I read that they may be outdated??
As much information on this topic as possible would be appreciated.
I also noticed that the intake pipe to throttle body gasket was torn and it was not metal either. The TB to IM pipe was ok, but I think it is cork. I heard that they are supposed to be metal.
I think that the throttle shaft seal might be bad because the sound varied as I changed the throttle position.
I hope that I did not remove the TB needlessly. Shouldn't some noise there be normal?
Thanks
Thanks
