Throttle Body Gaskets
lucid15
527
Oct 10, 2008
Portland, Oregon
I performed a boost leak test and found that i was leaking aroundt eh TB and BISS screw. so i ordered the two new TB gaskets, a new o-ring, and new BISS screw. Question is, what bolts do i need to unscrew on the elbow to the TB to replace the two gaskets i need to replace. i got one out, but the other 3 are either very hard to get to or impossible to even budge. Do i need to unscrew all 4?
If I remember right its 3 studs and one bolt. They are 12mm going into alum. so they will most likely be hard to break loose at frist. What I do is take the ractcht and smack it with a rubber mallet and the rest is cake.
and once all four are off, i can seperate the elbow from the TB to replace that gasket and the TB from the Intake mani to replace that gasket as well?
any suggestions on removing that last damn bolt at the bottom closest to the firewall? its such an awkward angle i cant do anything with it.
can i safely disconnect the three "vacuum" lines conected at the top of the TB? and what about the electrical harness? i need to in order to replace the second gasket.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
