OEM throttle body gaskets
98mitsubishigst
1,526
16
Nov 17, 2008
Pittsburgh, Pennsylvania
Just want a quick reassurance ..
Will the part number (60889) work on BOTH the inner, and outside side of the throttle body?
I can't find the other part number through advanced auto, but i was wondering if this gasket will work for both sides
(the side where the elbow meets the throttle body, and the side where the throttle body meets the intake manifold..)
This is the site with the part number..
http://shop.advanceautoparts.com/p/felpro-throttle-body-gasket-60889/19780175-P
This is the thread i read that you can use the same gasket on both sides..
http://www.dsmtuners.com/threads/local-source-for-throttle-body-elbow-gasket.453315/
Thank you!
I have no first hand experience using this gasket on both sides. However, if your local advance has them they are only a few bucks so give it shot. Inspect the fitment before install insuring that the gasket does not over hang into the bore of the elbow and post up pictures of your findings.
If you are not pressed for time and want a gasket that is made for the application, visit extremepsi or jnztuning to purchase OEM parts. They both have great customer service with outstanding shipping from my experience.
Robert
Hey man, no that gasket is only for the inner side, if you want the elbow side you have to buy the turbo gasket set threw advanced "stupid". If you want I have a couple elbow gaskets on hand. Hit me up ill give you one!
