throttle body gasket change
Big B
99
May 5, 2011
atlanta, Georgia
ok im just got both gaskets for the throttle body in efforts to fix a boost leak that seems to only leak under boost. does anyone have any advice on changing them or maybe a video on changing them beacuse i cant seem to find much on it. i could just hop right into it but im not to familiar with changing out anything that has to do with the throttle and i dont want to mess up anything. any advice or tips? thanks
There is nothing to it. Pop the throttle cable off, unbolt the 4 bolts, unplug the wires, drain the coolant a little so there is no fluid in the FIAV and remove 2 hoses (optional step). Then just make sure the mating surfaces are clean and smooth. You can apply a thin coat of RTV on the gaskets if you want but its not required.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
