throttle body gasket?
jbl_5star
150
Dec 14, 2009
Puyallup, Washington
where the gasket meets the face of the throttle body, the intake manifold side, theres small holes along the surface do i need to poke holes thru the gasket or just cover them with the gasket... and do i need to add anything like RVT between the metal and the gasket??
You just install the gasket as is without modifying it. You could use a very light coating of rtv if you like. I didn't use any when I intstalled mine.
The gasket will only really fit one way if you look at it. Also I would go with OEM if you have the option. Mitsu's intake gaskets have bonded orings in them that makes them seal very very well.
i know im not pushing more then 16 psi.. plus on a budget. here this will be better
its not semetrical, every side is diff<
this gasket
would the number sit on top?
Not to mention it will follow a contour from the TB as well. Flip it around and see what is lining up the best. As long as it's sealing what needs to be seald it's good.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
