Threw rod, have a question on 6 bolt swap
Bryce68
May 3, 2005
Lewiston, Minnesota
Allright here's the deal, I threw a rod on my '96 Talon TSI. it knocked for about half a minute very mildly on the interstate, I was NOT beating on it or anything, just crusing. I turned around to head back home, and all of a sudden it got LOUD, so I quick pulled off and shut it down ASAP. Towed it home, opened it up, #4 rod let go, pieces of rod and rod cap laying in oil pan, filings everywhere. Upon further inspection I found one of the rod cap bolts in near perfect shape and one nut in absolute perfect shape, and that about sent me through the roof. Punched a hole in the block, but head is fine thank god so I can at least salvage that. Crank and block are junk. I've never touched the bottom end on this thing, and I just bought it in september and have only put about 2500 miles on it since then. Now the question is, I called a salvage yard and they just got in a '93 laser nonturbo, those things have the 1g 6 bolt I'm looking to swap in right? My now junk 7 bolt block showed no signs of crankwalk, but I don't really want to put in another 7 bolt block and run the risk, and I can't find one anyways so it doesn't matter. I'm going to look at the laser today or tomorrow, and was wondering if there was anything in particular I should be looking for. Thanks.
first off, the engine in the nonturbo laser is a 4g63, but it is not built like the t4g63 that you had in your car. Your best bet to do a 6-bolt swap is to get a true 6 bolt shortblock from a salvage yard, or any other place for that matter. Should run you 300 bucks. Then you will need more parts to convert it to 6 bolt, search these forums for the 6bolt swap there is alot of dicussion.
If i were you, i would check to see the condition of your pistons. The 2g pistons are better than the 1g and the 1g rods are better than the 2g, so i would get a 6bolt block and have it built with 1g rods and your 2g pistons for a very strong budget motor. I'll be happy to answer any further questions you have.
90TTalonAWD has ya on the right path already there......reason he is saying to use a turbo block is that there is no oil squirters that squirt the bottoms of the pistons and I dont think(If I remember right)there isnt a tapped hole either for the knock sensor in the back on NON turbo blocks....and I too recommend to run the 1G big rods with 1995 or newer pistons because of the higher 8.5 to 1 compression vs the 7.8 to 1 compression of the 1G pistons,plus not to mention they are a little bit stronger of a piston too....it only costs like 100 bux to machine the rods to fit the pistons.
The 1g pistons are just as strong. You can run a lot of boost with the lower compression, which is great for pump gas. The non turbo block can be used, I think people use them without the squirters with high success, or they add them in I cant remember. There is a spot on the rear of the block you drill and tap for the knock sensor.
i think that getting the non turbo block is just a bad idea. even without the oil squirters and the knock sensor, he is still running stock nt internals with high compression:( he would but his t-25 back on at the stock 11psi and blow his motor instantly. The 1g pistons aren't terrible, they are just weaker than 2g. Same with 2g rods being weaker than 1g.
Damn, that is not what I wanted to hear...this is THE ONLY engine I have found locally after calling 4 or 5 places. Nobody even had anything until I called this place. I can get the whole 6 bolt turbo engine on ebay for 550 bucks, but they want 200 to truck it here, and I wouldn't be able to see the engine in person before buying it. My buddy does know a guy that races and builds dsm's and evos locally so I might give him a call. Money is kinda tight right now so I am definitely on a budget. Thanks for all the help and advice, it's greatly appreciated as I am still fairly new to dsm's, but am learning them quick.
Well I got the 7 bolt engine out tonight along with the tranny..would still appreciate it if someone would explain to me how to modify my driver's side engine mount for the 6 bolt. VFaq links to magnus motorsports as well..it's a pdf file and I do have acrobat but for some reason it won't let me open it up. Thanks a lot.
