Resolved Thread pitch bolt size and specification for Reverse Light Switch on Transmission
Atuca
Supporting Member
1,145
303
Jan 6, 2007
Central Valley, California
I am eliminating my reverse lights for my race car and want to remove the reverse light switch from my transmission and replace it with a short bolt/plug. I tried the local hardware stores and it appears to be an M14 bolt with a thread pitch of less then 2.0, but every store I went to only had M14 in a 2.0 thread pitch, and no way to measure my threads to be certain to try and order one from somewhere online.
So, my question is simple: What is the bolt size and pitch to replace the reverse switch with a bolt on a 2g AWD transmission?
Thanks.
Solution
according to that website:
Thread Size : 14 x 1,5
I will assume that to mean 1.5 pitch, and that is exactly what I needed! And if it is the same size as the oil plug, even better! Should make it easy to grab.
Thanks!!!
*edit* Just tried a oil pan plug, and it fits perfectly. You are the man!
That's not one I've measured but if you are certain it is a M14 diameter, then an auto parts store would have a M14 x 1.5mm pitch bolt/plug which is the common pitch for that size found on these cars. For example, our engine oil drain plugs (hint, hint).
I can check the size tomorrow if need be, but I'm confident if you try that size you'll be set: MD730979,MITSUBISHI MD-730979 Switch, reverse light for HYUNDAI,MITSUBISHI,VOLVO
Thanks!!!
Solution
