Thought there were differences in clutch's
gtbread77
131
Jul 17, 2010
windsor, Colorado
Hey guys I am in the market for a act clutch and came acroos this used one on craigslist. I thought that, and correct me if i am wrong there were differences in year 90-94 & 95-99 also awd & fwd. can someone please clue me in! New to buying clutches. Here is a link to the add eclipse act clutch
The clutches are the same for all 90-99 4g63 models. The difference is in the flywheel. But id recommend a new clutch as there is never any proof of the mileage on the clutch and pressure plate other than what the seller says
i could be wrong but isnt there a diff in a 6 bolt clutch and a 7 bolt clutch i forgot
Clutches are the same for all dsms. However, the flywheels are different between 1gs and 2gs.
Do some research, shopping for an ACT 2600 online would tell you the applications for it.
ACT 2600/6-puck
That guy in the CL ad is actually wrong, it fits 90-99.
Sweet thank's dude! does anyone happen to know the spec's on the thickness of the disc, just so i am not getting a clutch with 50k miles on it?!
Again, do some research its right on the website if you look for it. ACT Tech
Disc Thickness and Allowable Wear
The majority of our discs measure 8mm thick when compressed. The allowable wear for most discs is approximately 2mm of material (compressed disc thickness of 6mm).
:dsm:
