This is how to break the 9sec barrier!
cuzco
46
Mar 24, 2005
Reykjavik, Europe
god dam thats crazy. dident break anything this time :hellyeah:. also what is the lever next to the E-brake?
There's no such thing as a transmission brake on a DSM. That's what's called a "staging brake".
Nice, staging brake helps a lot in keepin the shock down!
Thanks guys. Yeah the blue knobed handle is my staging brake. It's nice to use it.
I'm now running a BorgWarner S366 T3 turbo on 43psi on those runs. I use a Hallman pro mbc. The Avcr is not even plugged in. No way it's a safc WTF ;)
Just updated my profile. This puts me kinda high in the 1/4mile list. Not bad for a DIY guy. No nos and all stock steel parts on car. Not gutted but no rear seats and rear interior. Is has roll cage, heater, outside mirrors, wipers and lights. Fully legal on the streets (has only downpipe for racing)
Congrats man the car is flying! I just got my car up and running with a s366 as well. I am running the .91 divided t4. Haven't been able to open it up yet but I can't wait!
The modlist if anyone cares ;)
6bolt
Stock crank
Eagle H beam rods
Wiseco pistons .020 over 9:1
Acl bearings
Oem mls hg
Map A1 H11/L19 head studs
Port matched and polished myself
Bc 280cams
Manley springs and titanium retainer
Kiggly HLA regulator
Evo rollers
Reviced lifters
Fidanza cam gears
Power enterprice timing belt
Clear cam cover
Magnus street intake manifold w/stock throttle body
Aem Ems for mangement
Set up for speed density
Aem wideband
Autometer boost gauge only 30psi
Aem serial gauge
Greddy egt
Rewired walbro 255
Inline Bosch 044
Fic 1650cc Bluemax injectors
Aeromotive fpr 43psi base
Dnp T3 manifold
Borg Warner S366 T3 @43psi
Tial 44mm wastegate
Hallman mbc
Custom 3" race downpipe
Custom 2.5" intercoolerpipes w/ tial 50mm bov
Sbr evo intercooler modified 3" thick
Converted to 4 bolt rear end
Reardiff solid mounted
QuarterMaster Twin Disc 7.25" V-Drive Clutch
Self rebuilt 91 trans w/welded center diff and double syncro 2nd gear
23 spline transfer case
Dss 3.5" driveshaft
Threespeed shatter shield
Driveshaft loop
Relocated alternaor
Prothane motormounts
Tein ss coilover
Strut towerbar
Fluidine Rad
2G front brakes w/slotted disks and hawk pads
Slotted rear disks
Goodridge braided lines
CNC brakes staging brake
Lico/sparco seats driver and passanger
Gforce and sparco belts
Rollcage
Rota sliptstream 16" Wrapped in 26" quick time pro's
Very sweet setup bro. :thumb: Any pics of the setup if you don't mind?
Im running the exact same turbo. I havent tried more than 25psi really. Im waiting for a few things to try out 40psi on c16. :hellyeah:
Car looks great, sounds great, and 9.6 is movin, congrats:thumb:
Awesome stuff, and it's almost a full interior car yet. What's up with the lines in the 3rd video?
Thanks. I'll see what I can find,
That should get it moving! :D
Thank you!
Thanks. I took everything in the rear out. I'll put it in again now and remove the cage. A true 9sec street car :D
My friends camera got f**d up or something ;)
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
