BoostedinSoFla
- 1,950
- 19
- Nov 1, 2006
South Florida,
Florida
I'm in the market for a rebuilt head since the one on the 6 bolt motor I have might need to be rebuilt. I stumbled upon this ad and it seems pretty legit but after speaking with the seller I'm kinda confused.
Description from his ad are as follows:
Talon/Eclipse/Laser DSM
2.0L 4G63 Rebuilt Cylinder Head in excellent condition
Had it rebuild a few years ago for a project Talon I was working on that I never ended up finishing.
I know the entire head was went through, valve seats reground and the valve guides replaced. I think those are the stock
valves and springs with new retainers. The 2 cam are also installed, and included with the head. Don't remember if the the cam sensor
is installed but I'm pretty sure it is.
THIS IS A COMPLETE HEAD
Rocker arms are installed and well as the cams and the cam retainers. This was the only picture that I had at the time,
it was taken before I reassembled it all.
Here's the convo:
Dear alyssajones23,
I have a few questions about this head and I am VERY interested in it. Is this a 1G head or is it a 2G 1995 (late 1994 built head)? Was the head properly decked to the correct tolerances? Were the lifters replaced and if so were they stock lifters?
Dear BoostedinSoFla,
Its out of a 93 eagle talon tsi. its 1G head. I don't remember if the lifters where replaced or not. It was decked and I was given a spacer for it. I think it was for the block though because it was warped and they had to mill it.
Dear alyssajones23,
I'm confused. You were given a spacer because the block was warped or because the head was milled too much? How did the black get so warped?
When I bought the car, it had a overheating problem. Turned out it was a bad radiator, but it over heated a couple of times on me. It still appeared to run fine and I wasnt leaking anything. When I pulled it a part and took it over to a engine/machine shop, I was told that the block was warped and they had to mill it down. And he gave me a spacer. He did the head and the block for me.
What else should I ask him about it? Does this sounds like it makes sense to you guys?
Here's the convo:
Dear alyssajones23,
Dear alyssajones23,
