Need help thinking of 6-bolt swap????
milenium99
45
Jun 9, 2004
bronx, New York
Have a 1gb and the engine is giving me crap, just rebuilt the head. Does anyone have any one know or have done a 6-bolt swap? Also would I be able to use a 6-bolt block and keep my 7-bolt head? or would I have to get the complete 6-bolt engine? and what kind of modifications be looking at to get it running?
Thanks in advance fan any input
junior
search forums and you will find your answers.the same question has been answered numerous times. Im sure if you search you will find what you are looking for. :thumb:
junior
What kind of problems are you having? Doing the 6 bolt swap is stupidly simple, even in a 2G. I'd imagine as long as you had all the right parts it would fall right into your car. You can keep your head but will just have to machine the headbolt holes 1mm larger so the 6 bolt studs/bolts don't get caught up as they are 12 mm vs 11 on a 7 bolt. You will need a 6 bolt shortblock including oilpan and flywheel as well as a new front case and oil filter housing. :thumb:
The six bolt swap in theory is easy to do but there are a lot of things you have options of doing. I.E. if you're doing the six bolt swap are you using the water cooled vs. air cooled oil cooler, leaving the balance shafts in or getting the BSE kit, random misfire codes if you're not using a DSMLINK setup (2g), etc. Just make sure you get all the info. you can and what your expectations are for the car as well as a budget. In the end of my swap I ended up spending a lot more than I initially intended.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
