think this is a bad idea?
crimsondragon
4,300
51
Dec 17, 2006
East Brunswick, New Jersey
So I decided to install my rear motor mount after like almost a year of owning them. I managed to get the mount out and lo and behold the Prothane inserts will not fit. WTF
Checked the packaging again and it said RR Eclipse motor mount 95-99. So now I'm just utterly confused as to why it won't fit. It has the right idea from what I can see but the mount is just too small. It won't fit over the rest of the motor mount.
So I decided to rip the middle of the mount out. Set the b**** on fire and let it burn. Meanwhile I fitted the inserts in, filled the inside cavity with industrial grade polyurethane. I used this same stuff for the front and I can say it's been holding up solidly. The only problem with this idea is the middle part for the bolt is too small. What I figured I'll do is fill the middle up with the stuff and just insert the metal sleeve. What do you guys think? I already have it in the garage curing. Good idea? Or should I just order the newer mounts?
i would check the part number you have with prothanes website and make sure you got the right one, you did grind the metal sleeves out of the mount right? after you burned the rubber out?
i just did a set on a friends 2g and they were the same as my 1g. had to burn the rubber out and then grind a groove across the inside of a sleeve to get it out, then once its out the inserts slide in the mounts with a lil effort,
I have the ones in the background. Like I said, no cutting of the sleeve required. They are suppose to slip between the spaces of the mount.
The new one are the inserts like the one in the background.
Slowboy Racing :: Engine :: DSM Engine :: Motor Mounts :: Prothane 2G DSM 4G63 Motor Mounts
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
