DSMmonster123
- 79
- 1
- Oct 15, 2010
South Florida,
Florida
Well I was going to go with a 1G bov but I ran out of money for this month sadly
, Ahh the life of a college student, anyway I had the day off and decided to attempt to mod my 2G bov so I could dial in my MBC and actually have the w/s gate open. Until today I had no idea what the MBC was set to b/c the bov leaked so badly. I had 14 psi wheather it was fully open or screwed shut.
so heres how to do it...
tools need
wire snips
needle nose pliers
a few screw drivers
an old flashlight
and most of all PATIENCE!
With the bov out of the car and looking into the low pressure/ intake side you see the small metal rod that connects to the plunger, the basic idea of the mod is simple, wind a spring around the plunger rod and increase the spring rate. The spring will come from that old flashlight thats been sitting around in the garage for years. You'll need a spring that is about an inch or so in height. As far as I know they all have about the same spring force but the heights will vary. I tore apart 2 before I found a good spring. Now cut off the larger coils that are close together on the bottom and trim the spring so it will fit through the opening on the bov. Be sure its still got plenty of force and is slightly larger than the distance between the plunger and the plastic nub that the rod goes through on top.
Now heres the tricky part try to wind the spring around the plunger shaft by rotating the spring, this will take time and patience, I used a few screwdrivers to hold and push the spring and the needle nose pliers to rotate it as well as my thumb. NOTE: if the spring is cone shaped place the smaller part upwards toward the vaccum chamber. I spent almost 2 hours trying to get the damn thing on but if you cut it correctly it may go on much easier. ABOVE ALL REMEMBER PATIENCE!! ITS ONLY PLASTIC!!, and if you're broke like me you can afford to replace it.
When done it should look like the picture keep the spring below the round plastic nub where the rod goes into the top. This will give you the proper amount of compression. On my first run I had a boost spike to 17 psi and imediatly backed off the throttle (It's basicaly a stock engine) so idk how much the mod will hold however Its a huge improvment over the stock setup. With the stock spring alone just putting the bov to your mouth and blowing you can hear it leak. With the mod that leak is almost gone and I now see around 10psi at about 1/4 - 1/3 throttle compared to the 1/2 or more throttle to acheive the same 10psi on a stock setup.
It's only worth the effort if you have time to kill, in hindsight buying a 1G bov is much less work and probably more reliable.
, Ahh the life of a college student, anyway I had the day off and decided to attempt to mod my 2G bov so I could dial in my MBC and actually have the w/s gate open. Until today I had no idea what the MBC was set to b/c the bov leaked so badly. I had 14 psi wheather it was fully open or screwed shut. so heres how to do it...
tools need
wire snips
needle nose pliers
a few screw drivers
an old flashlight
How would it get sucked into the turbo, its on the cold side of the intercooler?
haha. I haven't been recirc'd in so long I was thinking Justin was going crazy, good call!
