Thermostat housing to head still leaks?
lil corb
758
7
Sep 7, 2005
Woodbridge, Virginia
So I have replaced my crappy T stat housing paper gasket with an oem one:EXTREME PSI : Your #1 Source for In Stock Performance Parts
I scrapped the old gasket off the head and t-stat housing and I am still leaking from under the housing. I was thinking it was going through the bottom bolt hole so I RTV Ultra Grey'ed the the threads but STILL LEAKS!:confused: I was under the impression that Ultra Grey shouldn't be used when a good gasket is used but I'm running out of ideas and thinking of ultra grey'ing it around the outside of the gasket. It's not a massive leak but small drops.
When I removed the housing, I checked for cracks or warpage on both mating heads and it was fine..
Any ideas?
Thanks :thumb:
I was always taught RTV or gasket, never both. I'd only suggest Ultra Blue RTV for a 2g because they don't use a gasket. But for a 1g I would recommend installing the gasket completely dry.
I'd also check the mating surfaces with a flat edge to make sure they aren't warped.
Well I can't argue that for most gaskets and that normally works here too. It's just been my experience that smearing a VERY thin coat on both sides of a thermostat paper gasket has solved many a water leak. Especially if the surfaces aren't absolutely flat or you know there's a leak there. I wouldn't do it on an o-ring or the 2g turbo's thermostat with the rubber gasket on it though. Just a paper gasket thermostat. But to each his own.
Thanks everyone for their replies. I am going to sand the surface on both sides down lightly and try again. If that doesn't work I'm going RTV time! (Although I don't prefer this method) Thanks again.
I always use the gasket it self with out RTV, but if I have a leak which is very rare, then I go with Gray RTV and add just a light layer on both sides, practically, you just cover the gasket with rtv and remove it all what you can with your fingers to leave just a very tiny rtv on both sides and that will fo the trick and your RTV will not come out when you tight the bolts and looks like a mess.
So sand it down to make sure it's flat, Then light coat of RTV on both sides of gasket then bolt it down!
Got it, thanks!
So I actually removed all my hoses and looked at the housing up close. Still had very minor parts of the old gasket. Razor bladed it out and no more leaks!
