livedsm4g63
- 1,214
- 152
- Mar 1, 2008
Auburn Hills,
Michigan
I was wondering if anyone could help me with some pictures of where the bolts go that mount the transmission to the engine. I think i am missing the bolt that goes in the opposite way, as the other bolts. I have searched and i did find the vfaq that shows all of the bolts, but its not making sense. I have all of the front bolts in, and i noticed that i also have the bolt in, that is located under the starter bolts. (Bolts in the same as the start bolts.) Im thinking it is the 12mm bolt that is an 8X1.25 that goes in above the transfer case. (That you have to tighten from the engine side) The reason I say Im missing a rear bolt is because whenever i push in the clutch i see the rear of the transmission move a little bit. Im also having disengagement issues as well, so i think this is my problem.
