Tensioner Arm Components and operation
g4ebguy90
2,001
3
Mar 9, 2011
Rockford, Illinois
Hi, I am rebuilding a 1992 7 bolt engine.
I'm trying to make sure I am assembling right.
I am at the point of installing the tensioner arm. Problem is, I do not know how many washers or length of bolt I am supposed to have in it.
I also do not know the function, is it supposed to move even when tightened down, or is it supposed to say. As of right now, I have a bolt and 1 washer on, i tried 2 but I don't think that is right. I tighten it to around 20 lbs. The arm moves freely.
Here is some pics.
Thanks guys, I'm almost done.
yes its supposed to move, the tensioner applies pressure to the arm in turn the pulley mounted to the arm press's against the timing belt, if it didn't move it wouldn't transfer the force from the tensioner to the timing belt.
+1. if its not mounted right, the pulley wont be on the belt like it should be and could wear out the belt prematurely, so make sure when the belt is on the pulley, its in the middle of it and not riding on one of the edges.
Yea, I think I got the wrong pulley. Had to order a different one. Anyways So, I just put the big washer on and then the bolt and thats it??
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
