Temp and oil pressure gauge stopped working
ChiTownHussla
1,268
6
Nov 16, 2010
Chicago, Illinois
Hey guys I recently did my clutch and after the change, my temp gauge and oil pressure stopped working. Any ideas on what it can be?
There is a single wire (blue or blueish/green) which connects to the oil pressure sensor (located behind the driver's side wheel/wheel well). Check to make sure that is still hooked up and making a clean solid connection.
Here is a picture of it:
attachment.php
It is the single blue wire attached to the bell shapped oil pressure sensor.
Hope this helps!
check the wire. Also if its connected if you ground the wire should the gauge peg max oil press? Trying to remember how i checked mine... Either way i ditched stock one and have a aftermarket one i dont trust the just H and L.
attachment.php
Hope this helps!
Well i am gna check once it gets warm out. So. Which wire is it, the blue or green light see how blue on the left but also the green on the bottom right
