temp gauge stopped working
garrek11
201
Apr 4, 2009
Spokane, Washington
when i bought the car the temp guage worked then i drove it for a while then it stopped working then i installed a new tps since i needed one and it started working agian then recently it stopped working agian. any thoughts? and will my fans still work?
The sender for the gauge ONLY drives the gauge, nothing else. Its probably just a loose connection. The area around the thermostat housing gets VERY hot, and the wiring and connectors get very brittle. The gauge sender is a single wire sensor. Just wiggle the connector around and I'll bet that it starts working.
keydiver
where would the sensor be on a 420A motor i have a similiar problem i have the sensor on the front of the block which is the single wire sensor and the other sensor is by the thermostat which one would i be checking first??
[QUOTEwhere would the sensor be on a 420A motor i have a similiar problem i have the sensor on the front of the block which is the single wire sensor and the other sensor is by the thermostat which one would i be checking first??][/QUOTE]
it wont really matter which one you check first jsut figure out which isnt working LOL. but check the one near the thermo. like he said that are gets hot fast.
