TD06 20g flows 39 lb/min at 20 psi
Luckybob2485
140
Jun 20, 2006
Longmont, Colorado
I took my car to the dyno to get tuned with dsmlink. All was going well until my walboro fuel pump started failing. On dsmlink, i was logging just over 39 lbs/min at 20 psi. We would get the air/fuel ratio right on, then make another run, and it would run lean, and we looked at the injector duty cycle on my 850s, and they were at 78%. My defi link fuel pressure gauge went out recently, and they are expensive as hell to replace, so it looks like I need to get that gauge working, and get a new fuel pump. My last t28 was flowing 25-26 lbs/min, and put down 270 whp. So i cant wait to see what the 20g puts down. This car robs all my money, but it is so worth it.
Post the datalogs if you can, I'm curious to know how the 20g/TD06 comes on boost and all that.
I will try to post a log soon, its not nearly as laggy as i thought it was going to be. I would say it hits 20 psi around 3500 rpm. I am very pleased with it, and am hoping for 350 whp on pump gas.
Where'd you buy the turbo from and what are the full specs on it (i.e. compressor cover, inlet diameter, turbine wheel, turbine housing A/R, internal external gated). That kind of spool is awesome for a turbo with that kind of topend. You should be able to pull 400 w.h.p. with it or more.
