TD04 rebuild?
92dsmgst
92
Dec 9, 2008
Streetsboro, Ohio
I am about to attempt to rebuild a td04 on my 92 gst a/t. Any tips? i am kind of scared, i cant lie, but vfaq is going to be my best pal. I am doing the rebuild because i am getting excessive oil in my intercooler lines, and a mad boost leak that when i check it with the leak down test pressure only escapes through my dip stick tube... Hope i can solve the problem but some other imput would be nice.
spins free and no shaft play......just no explaination for the boost leak, it just comes out the dipstick tube
Then there is no need to rebuild the turbo and i'm really unsure where you are coming up with the connection between the two.
Did you leave your pcv hooked to intake manifold when testing?
It sounds like you have a lot of blow by if its coming from the dipstick, do a dry compression test, and if it shows very much fluctuation in the readings, follow up with a wet compression test, squirt a little oil into each cylinder and repeat the test, if the readings are higher than the dry test then your piston rings are worn. I dont know if this will help you, but I would check it before I started rebuilding the turbo.
Had the same problem dipstick keep blowing out tried bending the tube a little. Nothing I tried would work come to find out cam was off a tooth fix the timing now everything is good to go
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
