taking a motor from a 96 gsx and droping it in my 95 gst
Hitmachine101
352
Nov 16, 2009
Rochester NY, New York
besides the obvious transmission issue which i have covered, will there be any other issues dropping this in? concerned about the obd2 vs obd1 issues
no theres no problems, 95 and 96 are the same and you shouldnt have any tranny problems either, i actually use a gsx pressure plate in my gst and it works fine. its the 97 and up motors that are different.
95-96 should have no problem, but aren't the 95-96 motors more prone to crankwalk? Why not build your current motor up? I was considering a motorswap, but instead found it cheaper to rebuild it. 6 bolt swap does take a long time if you have an auto.
everything will swap fine, but may i ask why youre wanting to swap? Get a 6 bolt
im swaping in the 96 because my motor in the 95 spun a rod bearing HARDCORE by the Previous Owner and i was tricked into buying the car being told only the head needed work
im just trying to get the car to run solid as a daily driver,,, real reliable cars if you know what your doing and dont boost the hell out of them LOL:D
if i were to build the motor it would be a 6 bolt for sure and id have some fun with her but not as a dd LOL
