defiancy
- 0
- Feb 6, 2006
San Diego,
California
I've got a few questions/problems that maybe you kind folks can help me out with.
I just installed an AEM AFPR into my car and set it to 38 psi. Prior to that my car started up pretty much instantly when I would crank it. After the install the car now takes a good three-four seconds of cranking before it fires up and starts. Sometimes I'll crank it and let off and it'll sputter and start up. The car runs fine otherwise and according to my AEM wideband my A/F ratio is normal as well.
What could be causing this delay?
I also am getting extremely horrible gas mileage. I generally fill my tank up all the way with 12 gallons or so. That 12 gallons will get me about 200-220 MPG, compared to an old 95 GST I used to have that got at least 280-300 per tank. What could be causing this? I haven't noticed my car running super rich and the car idles and drives fine, it's just getting horrible mileage.
And finally a few boost related questions. Sometimes when I am under boost and get above 10-12 psi my car will stutter for a few moments in the middle of boosting. The A/F ratios look fine, if not a bit rich when I drive at mid-WOT throttle. Just wondering what I should check or what that stuttering could be?
Here are the mods on the car:
Full exhaust, 3' GM MAF + MAFT, Greddy RS BOV, 550cc injectors, rewired 190, intake, AFPR, MBC,
I'm still running the stock 1g side mount and a stock 14b set at 19psi. Aside from what is mentioned the car runs great and has no other problems. Thanks for your replies!
) to create an angled seat for the ball instead of the original 90-degree angle, and this solved his problems.
