dwdsm
- 596
- 48
- Apr 28, 2005
Scenery Hill,
Pennsylvania
These are the two posts I've had on link for a few days. I'll throw it out here also.
This is the fist time I was the lead guy on a DSM build and so far not so good. Car info.
2g
16g
RC 550's
255 fuel pump
6-bolt swap
black top cas
forged rods and pistons
built head stock cams
dsmlink v2.5
I bought this car to part out and my friend wanted to bring it back to life. I used what the previous owner said was his map and it looks correct for a 16g and 550's.
The car is breaking up bad and then when it builds boost it will smooth out but it acts like it is hauling a boat.
We checked the timing twice as well as the cas. It's spot on however the wierd thing is I always remember grounding timing when setting 5 btdc. If we did this it would loose the timing mark on the crank pulley totally. We are going to do a compression test and check for any shaft play this weekend.
Please look at his log settings and see if anything jumps out at you. As you can see we really can't even get on the car to see what happens.. it so sketchy.
Did a boost leak test and fixed all but the throttle body seal leak.
Compression test showed 160 across all cyclinders
Turbo spins freely and has no shaft play
Swapped mas with no change
I was then thinking ignition so we swapped one coil pack with the only good one I had and it got rid of the studder at low RPM. The car now will cruise fine but still seems sluggish. Here is the log and we would have taken it further but we need to get a boost controller or a new actuator before going any further.
The seals and coil pack is on order now.
2g
16g
RC 550's
255 fuel pump
6-bolt swap
black top cas
dsmlink v2.5
