T4 Divided vs V-band - ApexTurbo Dyno Testing
MorrisonFab
Supporting Vendor
358
1,396
May 28, 2017
Johnson Creek, Wisconsin
1.15 A/R T4 Divided vs 0.82 A/R V-band- 6466 ApexTurbo Dyno Testing
Here is the first round of back-to-back dyno comparisons, on @perrytheplatypus157's AWD ’90 Eagle Talon. 2.0LR, 10.5:1, cast wet block, GSC S3 camshafts on pump e85, with dedicated v-band and T4 divided turbo manifolds. Each setup purpose built to share the same components- same turbo, same turbo placement, same two wastegates- although not necessary with the non-divided v-band it kept boost control more consistent between setups, 3.5” downpipe/full exhaust, same runner size- even the same primary lengths. All done on the same day with the test car never unstrapped from the Dynojet chassis dyno. Runs were done in 3rd gear with similar stabilized fluid and hot parts temps, and each run starting from a steady state/no load 3000rpm.
The turbo is an Apex 6466 with either their 1.15 A/R T4 divided or .82 A/R v-band turbine housing, tested across three boost levels, and matched within ~1psi to each other using a manual boost controller (air regulator to the top wastegate port to effectively increase/augment the WG spring rating).
DSPORT’s 2016 twin scroll vs single scroll test, “The Great Divide,” was a great example of what to expect from Garrett divided/non-divided v-band turbine housings, each paired to the same divided v-band turbo manifold. Today, most turbine housing options fall between v-band or T4 divided, using completely different flanges and manifolds. It’s not uncommon to hear that a non-divided v-band option will out-spool their older 4 bolt flanged counterparts like T3 and specifically T4 housings- even T4 divided. There are instances where that could be true, but we’d argue the quicker spool/response would come from incremental, secondary improvements. Improvements perhaps stemming from a more recent redesign, more ideal casting material such as stainless steel with its lower thermal conductivity, smoother investment cast internal volutes vs rougher sand cast housings, potentially tighter tolerances and blade clearance, maybe a round flange that better matches your round crossover, or just tending to be paired with newer aero/tech turbo options- skewing the perception. They require entirely different turbo manifolds, too, where certain design changes can play a surprisingly large role. Something we’ve seen through multiple back-to-back tests over the years.
There are certainly things we like to take advantage of with v-band turbine housings, but when it comes to spool- does the turbo care about what fastens the flanges together? Does it care more about how many volutes/scrolls there are? Does the increased spool come at the expense of high rpm performance, and if so, how much? Is the extra cost/complexity of twin scroll worth it? Does it even work on my engine?
What are some considerations you have when choosing which turbine housing?
The different A/R ratios:
The T4 divided A/R being tested is ~30% larger than the 0.82 A/R non-divided v-band. A/R is a ratio, but since each share the same turbine wheel, you end up with a larger or smaller exhaust area/nozzle to drive the turbine. By itself, this would cause the larger A/R to spool/respond slower in exchange for more flow capacity, and smaller A/R to spool/respond sooner at the expense of some flow capacity.
It’s tempting, and seems logical to use the same A/R in a back-to-back test like this to eliminate a variable, but arguably the divided turbine housing requires it due to how the individual exhaust events are split up to function.
Side-by-side and cross section of a non-divided and divided housing (not the exact housings used)
Our reasoning behind it:
-The combined volute area of the divided housing is larger at 1.15 A/R, but each cylinder/exhaust pulse only sees half of that volute/nozzle area at a time- and only half of the total cylinders traveling through it, with no overlapping exhaust events. In the non-divided example, each cylinder sees the entire 0.82 A/R volute/nozzle of the v-band housing, shared by all cylinders and their exhaust events.
-The divider wall in the divided turbine housing comes with additional friction/wetting losses, which can add to the exhaust manifold pressure (EMAP) by itself.
If the A/R were the same 0.82 A/R between both housings, the divided would almost certainly spool sooner, but due to the above, the divided would be more likely to choke/nose over in power due to higher EMAP at higher power/rpm levels. A 0.8x A/R in a divided housing can yield great results, and often paired with smaller turbos, but would arguably be undersized for this comparison.
Conversely, if both divided and non-divided were 1.15 A/R, the non-divided v-band housing would likely be oversized for this combination, losing appreciable spool rpm and at the point of diminishing returns where it’s unlikely to pay off elsewhere with this turbo size/combination.
So they are different, but arguably for good reason, and why many turbine housing offerings share this same trend. Including the options available for this turbo. Comparing the exhaust pressure readings later, they seem pretty well matched for the test.
There are plenty of other factors in deciding A/R in general, and apparently some manufacturers who already upsize to compensate (potentially Garrett’s divided v-band in the 2016 DSPORT test?), but we’ve heard/found ~25-40% larger than a comparable non-divided A/R turbine housing is a good rule of thumb. Especially if you already have a reference A/R on a combination that's known to work well. Finding that ideal A/R, at least from what we've seen, is more of a balancing act with diminishing returns if you stray too far away.
In general, increasingly larger turbos tend to use increasingly larger A/R’s, and larger displacement engines tend to use a larger A/R. The ‘formula’ starts to fall apart when comparing different manufacturers and turbine wheels/designs, etc.
In anticipation of seeing what happens on the dyno, we set a benefit/loss benchmark to help avoid bias in the interpretation of the results. A rough estimate, but every ~100whp (or ~10lb/min) of turbo flow potential gained tends to lose ~300-500rpm worth of spool on a 2.0L 4G63. Let’s call it 400rpm. So something like a 400whp capable turbo setup that comes in at 4200rpm or a now 600whp capable turbo setup that comes in closer to 5000rpm, for example. Or a turbine housing A/R change that lands somewhere in between that give and take for potential power and spool.
So, if the divided configuration didn’t exceed that benefit/loss ratio by a good margin, losing less than ~25whp for every 100rpm of increased spool, a simple turbo or A/R change could do the same thing. With less cost/complexity that tends to come with a divided setup.
The results-
Horsepower curves:
Torque curves:
All runs matched within ~1psi or less between each setup at full boost. First three are horsepower at the wheels, bottom three are torque at the wheels, each showing the ~35psi, ~45psi, ~50psi boost comparisons and their respective boost curve overlays.
Slight Boost Variances:
Boost in the bottom portion shows slight variances that can/will influence the power/torque comparisons. When both reached full boost, the v-band setup sometimes had a 0.5psi boost advantage after 7000rpm, and as high as 1psi at the end of the highest boost run. In general, the v-band setup tended to hold boost a little better with the manual boost controller used, particularly during higher boost runs. An identical boost curve at every rpm point would be nice, and could have been dialed in with electronic boost control with enough pulls, getting each more flat/consistent. In practice, the slight boost curve variances with rpm are just another layer to each setup’s characteristics.
Wideband readings are also added for reference, with each sharing the same AFR target. The target AFR gets richer with more boost, so much of the “difference” is just due to the divided coming into boost sooner- and commanding a richer AFR sooner.
HP, torque, and boost curve overview:
The divided setup consistently came into boost ~380rpm sooner, reaching 30psi by ~4830rpm vs the v-band by ~5220rpm, even with the divided having a larger A/R than the v-band housing. Once both reached full boost, the 0.82A/R v-band setup saw 1-2% more power in certain spots when overlayed. Peak power/torque numbers ranged from 3-15whp and 5-14wtq, tending to show more variance as boost levels increased. Partly due to the boost variances above, but still closely matched overall in dyno power and torque numbers. The v-band surprisingly (to us) made a little more power at the same psi in the midrange rpm. The power curve shapes at full boost were almost identical, with neither setup nosing over, even during later runs to 9500rpm.
Exhaust manifold pressure (EMAP) and zooming in on the boost curves:
The zoomed in boost curves better illustrate the slight variances between the two configurations. The EMAP sensor signal dropped out in some runs, but another similar boost run could be referenced for the ratios later.
EMAP overview:
Before 7000rpm the divided had lower exhaust pressure (EMAP in psig) for the same boost, at ~7200rpm both were nearly the same, and by 9000rpm the divided was a few psi higher EMAP than the 0.82 A/R v-band, even with its larger 1.15 A/R. Since EMAP influences boost control through the wastegate valve, the lower EMAP of the v-band lines up with it holding boost slightly better up there.
EMAP was still impressively low overall for the turbo size and power levels. There are many factors, but much of that credit goes to the turbo itself- requiring less average exhaust pressure to maintain the boost pressure and airflow throughout most of the testing. A 1:1 ratio wasn’t seen until closer to 900whp and 50psi of boost.
(~45psi run wasn't comparable due to the EMAP sensor dropping out early)
During the highest boost setting tested:
At 9000rpm the 0.82 A/R v-band was at a 1.15:1 ratio of exhaust to boost pressure.
At 9000rpm the 1.15 A/R divided was at a 1.20:1 ratio of exhaust to boost pressure.
Also referenced as exhaust pressure ratio, drive pressure ratio, engine pressure ratio, EMAP/IMAP, EMAP/MAP, etc. Lower exhaust pressure at the same boost, resulting in a lower ratio, is generally a good sign when it comes to turbos and the setup in general.
EMAP trends and the EMAP/IMAP relationship give valuable insight when analyzing anything turbocharged. Particularly when it comes to explaining the difference in turbos themselves; such as why one turbo will tend to make more power at the same psi than another, gauging how hard a given turbo is being pushed, fine tuning/matching A/R size, etc.
It still carries important information in a test like this, with the trend of each EMAP flipping/crossing each other being very interesting, but falls short in fully explaining what drove the divided configuration into boost sooner.
Underlying mechanisms behind the results:
When trying to understand the “why” behind these results, it’s easy to focus on the turbo side of things. After all, the only components swapped in this test were the turbo’s hotside and a matching turbo manifold. But the characteristics between each setup may become more intuitive by considering what’s happening to the engine with these changes. Looking through the engine’s data logs from this test gave strong indications that the potential spool differences, and perhaps much of what’s driving them, are coming from the engine side. Things like engine VE/cylinder filling and specifically exhaust blowdown interference. Negative effects that can be eliminated if certain cylinders can be paired/separated up to the turbine wheel, and profound enough to be easily felt from the driver’s seat.
What is exhaust blowdown interference?
A nice diagram from Mazda showing the exhaust path between cylinders with a common (4 into 1) collector, and the affected rpm range. Their example is naturally aspirated, but the effect is likely even more pronounced with a turbine wheel partially blocking the exit.
At its simplest- a negative effect that can happen when two or more cylinders have their exhaust valves briefly open at the same time.
What can happen- the exhaust from one cylinder during its blowdown phase, with the exhaust valve initially opening and sending out a large pulse/rush of exhaust, travels through another cylinder’s open exhaust valve and into that cylinder.
Exhaust reversion caused by another cylinder.
In a 4 cylinder (or 2 rotor that shares the same 180deg blowdown interference), that offending exhaust pulse arrives at a very inopportune time. The blowdown interference happens near the end of the exhaust stroke, as the exhaust valve is closing, leaving little or no time to evacuate the exhaust contamination back out.
What we truly care about is the following effect: any exhaust gas that remains in the cylinder will displace intake air charge during the following intake stroke. Exhaust gas displaces your engine’s displacement, hurting cylinder filling, and we have a great way of seeing that through changes in engine volumetric efficiency (eVE, or just VE).
Side note:
We’re talking about engine VE that compares what is in the intake manifold (measured by a MAP and IAT sensor) to what % of the cylinder is filled with that awaiting air mass after each complete engine cycle. This isn’t VE that compares to outside/atmospheric air, where “VE” values could exceed 100%, 200%, 300%, etc., heavily skewed by the boost level, but engine VE with all the temperature and density/boost variables already accounted for. More boost actually tends to lower “true” VE, but that could probably be its own article. This data is what many speed density tuning programs base their calculations on, and generate a VE map from, by calculating/inferring by how much extra fuel it takes to maintain the same measured air fuel ratio, and in-turn, how much extra airflow is going through the engine, per complete cycle, at those points. That makes before/after changes in your VE map an excellent reference to see how efficiently your engine is filling the cylinder at various rpm and load points. A convenient tool to trace where certain components affect the efficiency of the engine, and by how much.
What does that mean to you?
Since engine VE what % of your engine’s cylinders, and total displacement, is being utilized during various operating conditions- another way to think about it is what displacement the engine is acting like at each of those points. For example, at 80% VE, this 2.0L would only act like a 1.6L at that operating condition/rpm and load point of the VE map. That’s very noticeable and, thinking of the VE map as an “effective engine displacement” map, makes the VE% changes much more tangible. And those changes come with the exact same knock-on effects that come with a larger displacement engine when it comes to boost, too. More airflow to drive the turbo into boost sooner, often more power per psi, etc.
Back to blowdown interference.
The other part of that Mazda diagram, showing one way to mitigate blowdown interference and the rpm range (less) affected.
There are many ways to mitigate the negative effect of blowdown interference, but a divided turbo setup can completely eliminate it. The cylinders are intentionally paired so no exhaust valves will be open at the same time, separating them from the cylinders that do, and cutting off the shared exhaust path entirely. No more blowing exhaust into another cylinder, no more engine acting smaller due to it.
For an inline 4 cylinder, 2 rotor, and 6 cylinder, the cylinder’s exhaust runners can be properly paired and sent into each side/scroll of a divided turbine housing to avoid negative cross talk/interference on the exhaust side.
With more cylinders however, or an odd count, you can’t effectively separate/organize the cylinders into two scrolls where no exhaust valves are simultaneously open. So not all engines can effectively utilize a divided turbine housing.
Since the 180deg blowdown interference experienced by our 4 cylinder happens near the end of the exhaust stroke, one way to mitigate its negative effect is by shortening the time available for the exhaust to travel and narrowing the time window that it can occur. This naturally occurs as engine rpm is increased, while the exhaust pulse is more or less fixed/limited by the local speed of sound, now unable to reach another cylinder before the door is shut on it.
So, now we have a case where blowdown interference should be practically eliminated (divided), and one where it should be prevalent at lower rpm (non-divided) but eventually fade away with increasing rpm until there isn’t enough time to interfere at all. Overlaying the dialed-in/calculated VE curves during the run of each setup as they sweep across their VE maps gives an elegant comparison. Highlighting the scale/magnitude, and at what point they converge as the effect naturally fades away- divided or not.
*This relies on a well dialed-in VE map, stable fueling (no fuel pressure drop off, etc.), stable/controlled air-fuel curve, and accurate wideband O2 readings for feedback throughout. All of which were handled by Haltech with any slight fuel trims being accounted for, using ‘Base Fuel Tuning’ + ‘O2 Control Output’ for the final VE values shown. The absolute values could still be potentially skewed, but it’s the % change between setups that truly matters.
VE vs boost and rpm. Top graph portion is VE, bottom portion boost in psig:
At the start of the run at lower rpm, the difference in VE during every pull hovers between 20-22% VE around 3000rpm, getting closer to a 15% difference by 4000rpm, and each setup’s VE curve steadily converges by around 5200rpm at every boost level, with the v-band seeing ~1-2% higher VE after 6500rpm in the ~35psi and ~45/42psi comparisons. It’s small enough to still be a coincidence, but this 1-2% additional VE matches the power difference the v-band saw before. Likely influenced by the lower EMAP of the v-band vs the divided housing.
The initial shape of the red v-band VE curve, the one that would be experiencing blowdown interference, is increasing at a satisfyingly linear rate as rpm increases, which is exactly what you’d expect if there is less and less time for the negative cylinder-to-cylinder effects to take place.
22% difference is significant; on the scale of ~0.4 liter difference in engine displacement when it comes to driving the turbo and noticeable off-boost torque around 3000-3500rpm. Whether you imagine it as the non-divided acting closer to a 1.6L at that rpm, or requiring a 2.4L+ engine to match the divided 2.0L setup due to the negative effects caused by blowdown interference. At 4000rpm a scale of ~0.3L displacement difference, 4500rpm ~0.14L, 5000rpm ~0.05L. (a better visual would be ideal here)
During that affected range:
Divided=less negative interference->less residual exhaust gas->better VE/cylinder filling of air/fuel->engine effectively acts larger->more airflow generated through the engine at the same rpm->quicker into boost.
The differences between these VE curves- where they merge, how much initial difference there is, overall shape, rpm dependence- strongly suggest exhaust blowdown interference between cylinders. If that’s the case, there will be some implications. A significant one, one that should be somewhat predictable in how things shift around, are the camshaft(s) being used. Specifically the exhaust duration. Longer exhaust duration will open the door for more blowdown interference and cause it to happen sooner in the exhaust stroke/event, requiring even higher rpm to navigate out of the negatively affected range. More duration-> higher rpm before the negative effects can go away on their own. The initial drop in VE could be even more pronounced as well, since with more duration comes more valve overlap (when the intake and exhaust valves in the same cylinder are briefly open at the same time). Valve overlap also occurs at the end of the exhaust stroke, giving the exhaust blowdown interference the opportunity to travel up into the intake tract if things get bad enough- no longer constrained to the size of the combustion chamber alone.
McKenzie’s car in these tests was using GSC S3 camshafts, which have a longer exhaust duration vs something like the milder S2 option, meaning his S3 leave more available for the divided configuration to “clean up,” offering more to improve on at low rpm, which will tend to show a greater difference between divided and non-divided setups than the S2 option. Or, for factory camshafts, the negative effects could be rpm’d out of well before that, and show little difference during spool on a turbo that comes on closer to 5000rpm.
Lots of factors, but the differences a divided setup can make are likely to scale with camshaft duration and overlap. This lines up with something we’ve noticed- a divided setup tends to be less sensitive to camshaft duration and overlap, and mitigates the usual “softening” of the bottom end that usually comes with it. You are often able get away with more aggressive camshafts with fewer ill-effects/trade-offs in the lower rpm range. This seems to apply to intake and exhaust cam timing as well, which could result in some interesting future comparisons.
You may notice that the VE differences were minimal by the time each turbo/setup was fully into boost around ~5500rpm, potentially keeping the spool differences between divided/non-divided closer than anticipated at ~380rpm. Maybe a smaller turbo that reaches full boost before 5000rpm could see a greater rpm split, for example. Maybe not. We have seen greater differences in spool, closer to 600 to 1000rpm, but the test results here are likely more representative of the difference between two configurations that are already well optimized. A/R size, arguably manifold design, etc.
The benefits that can be seen on the exhaust side can quickly diminish depending on how well the baseline setup is doing, and how much residual exhaust gas there is to clean up. After installing our test v-band manifold/turbo setup, and compared to the v-band manifold/turbo that was on the car (a makeshift one, not the one some may be thinking), there was a significant change in VE/fueling requirements at the onset of boost. The new APX6466 v-band combination was already indicating ~15% higher VE during spool up, a similar change to what I expected when going to the divided setup, making me question how much was left in the VE/spool department for the divided setup to improve on.
Other factors at play:
Some things on that 'incremental improvement list' applied here, outside of just the measured VE changes that we focused on. The turbine housings had different casting materials/techniques and surface finishes which may have played a small role. There could be something to the fact that each divided exhaust pulse only “sees” half of the turbo manifold and half of the turbine housing, reducing the total volume for the exhaust pulse to expand into. We've seen that increase boost response by itself. There could be something to what happens to turbine efficiency, pulsed vs constant flow, whether or not the pulses/events are ordered or overlapping when they hit the turbine wheel, or if certain turbine wheel designs tend to favor one or the other, etc.
We can't personally speak to a lot of those things, but they also put a lot of focus on the turbo/turbine side of things when there was a significant measured effect on the engine/VE/cylinder filling side. Something that we think has been missing in many open vs divided conversations, at least in our 4 cylinder applications. Effects that may explain the characteristics/mechanisms behind each and why some engines/configurations may not see similar results.
You may be wondering, what about a smaller A/R v-band housing?
Wouldn’t a smaller 0.63A/R offer quicker spool than the 0.82A/R and do the same thing as the divided setup? It could close the gap, but a key difference comes down to how each go about increasing spool/response. A smaller A/R shrinks the nozzle/volute size in the turbine housing, increasing the velocity of the exhaust gas driving the turbine wheel, which generates boost sooner but at the expense of higher EMAP across the board. It would certainly make for another great addition/data point, but likely come back to that ~25whp loss for every 100rpm gained in spool in our 2.0 4G63 application. The divided setup works fundamentally differently- allowing the engine to work more efficiently by increasing VE to achieve the same result.
I find it interesting that this also makes a divided setup less likely to experience compressor surge at the same boost/rpm, due to the engine ingesting more airflow at the same rpm (which is driving the turbo quicker into boost), moving the operating point further away from its surge line on the compressor map. A smaller A/R alone tends to move things closer (up/left on the compressor map) to the surge line during spool up, making compressor surge more likely.
Only partially related, but I really wanted to mention it somewhere:
The divided setup was able to hit 30psi at 4050rpm when messing around in 5th gear (and no surge). Pretty phenomenal for a 64mm turbo on a 2.0L engine; with many components that are tailored more towards high rpm to boot. Pretty relevant for an auto car that's looking to build boost on the stall/torque converter.
We came into this test with some theories and expectations, but more importantly just wanted to see what really happened. To see a solid comparison and overlays between two dedicated v-band and T4 divided setups with minimal variables. On the same car, same day, same turbo.
Still to be done are the 0.96 A/R T4 open/non-divided comparisons, which will make for a great "control" test, perhaps putting a finger on some of those incremental changes mentioned before and verify the VE trends. Hopefully some other test approaches to further tease out the mechanisms/effects that could still be at play.
A great opportunity to see how our predictions play out, too. I expect the non-divided .96A/R T4 to behave very similar to the non-divided v-band housing, just with a larger split in spool rpm due to the closer/larger A/R. And the non-divided 0.96 A/R should end up with less EMAP for the same boost (and a better EMAP/MAP) than the 0.82 A/R v-band, potentially resulting in the highest peak power numbers overall.
Hoping to find out soon
Takeaways:
The non-divided v-band setup showed slightly lower peak EMAP, tended to hold boost slightly better at high rpm, resulting in slightly higher power numbers (1-2%) when at full boost when compared to the divided combination.
The divided setup showed ~380rpm quicker spool and immediately noticeable off boost torque, similar to a larger 2.4L engine at low rpm, with the differences fading away as rpm increased. Each run required a touch more from the manual boost controller to reach the same boost as the v-band setup
The dyno curves were remarkably close once full boost was reached, with neither nosing over- even during later pulls to 9500rpm
The larger A/R on the divided housing was more than offset by the VE benefits when it came to spool characteristics in this test, and the larger A/R likely helped offset losses at high rpm
Exhaust blowdown interference (and the subsequent residual exhaust gas hurting engine VE) looks to be extremely prevalent at low rpm in non-divided inline 4 turbo setups, and likely a large factor in the spool differences seen in this test. Camshaft duration is likely to have a large influence on the differences as well.
The results of this test, and the exact rpm/spool/power differences, won’t apply to every turbo/engine/manifold. Many push-pull factors involved, with this test showing the difference between two arguably well optimized configurations. Although this test showed the largest difference to date with a single design change, we could see things skewed further in either direction due to other turbo manifold design changes we’ve tested over the years. Compromised designs/components could flip the results over.
The differences from a divided turbine housing, or if it even ‘works’ at all or not, are highly dependent on the engine, cylinder count, and correct pairing.
2 rotor engines are likely to respond similarly due to sharing the same 180deg exhaust blowdown interference. 6 cylinder engines will have 120deg blowdown interference, likely influencing the mechanisms behind spool/response/power characteristics. Even 4 cylinder boxer engines, with their inherently longer runner lengths and larger overall runner/manifold volume could influence how large of an effect each mechanism mentioned here has.
8 cylinder engines don’t allow correct cylinder firing order/pairing to see the same VE benefit, unless it’s a ‘Hot V’ with 2x divided turbos, etc.
For the opposite reason, with so few exhaust events and built in 240deg pulse separation, an even firing 3 cylinder already avoids blowdown interference and doesn’t require dividing anything up. Not that you really could anyway.
The Apex line-up is becoming well known to punch above its weight in power, and we were genuinely impressed by the 64mm setup overall in both power and response. Can't say I've seen a wider power band from a 900whp+ 2.0L 4g63.
Playing with a bellmouth inlet on the divided setup improved spool another ~120rpm, and yielded 922whp that was still slightly climbing at 9400rpm (46psi at that power level/point), likely with more improvement to be had with electronic boost control, less conservative timing/AFR, etc.
The additional response and driving characteristics offered by the T4 divided was exactly what McKenzie was looking for from his street car, and is ultimately the setup he is sticking with. His previous setups embraced the simplicity of non-divided turbos, with very notable results, but constant experimentation keeps things interesting.
The increased response and better street manners now add the temptation of the next size up turbo, likely resulting in the same or still better spool/response than the 64mm v-band combo, while retaining the extra power potential on tap of a larger turbo (likely lowering EMAP further, too). This is how we like to leverage divided turbo setups when turbo size isn’t constrained.
For small displacement, automatic turbo cars that need to build boost on the converter, the spool/VE characteristics of a divided setup can make a large difference exactly where it's needed. And, based on what we saw from this test, without hindering high rpm capability like a 2.3L stroker setup for example.
For compressor limited classes, that don't have a need for spool down low, a non-divided/v-band housing could certainly be more ideal. The v-band tended to hold boost a little better, and made slightly more power when at full boost during this test. Less cost/complexity, generally lower drive pressure at high rpm, and potentially the most power out of a given turbo. Things like smaller outer dimensions on a v-band turbine housings can sometimes allow better packaging and/or fit a larger exhaust size right after the turbo, which could slightly improve overall power and spool as well.
It’s also worth mentioning some non-divided combinations that help close the gap in response through clever tech and design, such as the Xona Rotor UHF turbine wheel when paired with smaller than ‘typical’ A/R housing in our applications, while still maintaining low EMAP.
We genuinely appreciate what each configuration can offer, are fascinated by the characteristics/mechanisms behind them, and have wanted to share an example of what folks could expect from each for a long time- including potential variables behind the various experiences/results over the years.
Our inline 4 tends to prefer the divided setup, and the turbo tends to prefer a turbine housing without a divider wall.
What are the considerations you have when choosing a turbine housing? Did they change?
Huge thank you to DSPORT, ApexTurbo and McKenzie Lange for all of their time, effort, and resources put into this test, with the shared goal to let folks see what each turbine housing/configuration does, and align with what they are looking for from their turbo setup.
More miscellaneous stuff:
All testing was done with a turbo inlet mesh/filter. This PMAS unit showed no change between dyno runs vs a bare turbo inlet, likely due to them calibrating the integrated bellmouth to offset the flow losses from the mesh/filter.
A full bellmouth with no mesh, and short inlet pipe to make it fit (also a better inlet location), increased spool by ~120rpm on the dyno and raised boost everywhere, despite less turns on the regulator/boost controller.
One last thing-
Spool on the dyno was about 150rpm slower than on the street with both setups (3rd gear rpm to reach 30psi, 4655 vs 4815 for example)
That is a really enjoyable read. I've compared the Vband VS twin scroll on a 2jz before and it was a 1.28 divided VS a 1.0 VB. In my test the VB was the winnder but with a 85mm turbine there wasn't alot of action below 4,000rpm.
I am sure you have a bunch of time wrapped up in this and I'm extremely proud of you for taking the time to put this together. I keep buggin my brother Tim to have you build him a new turbo system for his Evo. Your work is lovely !
Thanks for posting all this info @MorrisonFab - the community appreciates it! Reminds me of the old days of forums, where long posts like this were a common occurrence. Now all you see is marketing fluff posted on social media to get followers and likes by most companies. Kudos to the Morrisons for reminding us all why car culture is so cool. And that some companies still give a damn.
Great post, awesome data, to bad no one can buy one of these w DP from you but great to see you're slammed with work.
Curious, why twin gates vs say single 50mm on the Vband?
Thank you!
Getting within ~1psi setup to setup tends to be one of the more difficult parts of a back-to-back test. The 2x gates on the v-band isn't necessary (you're 100% right about a single 50mm being more typical), but it cut down on time/runs spent dialing in the boost levels between setups. Really glad too, since the same wastegate(s) allows a direct comparison on boost control trends.
Even the small vs large test last year, with fewer things changed, showed the small runner requiring less WGDC% for the same boost, and being more likely to boost creep. We had seen a general trend over the years, but you don't really know for sure (or to what extent) until dissecting a dedicated test.
In this divided/v-band test, we were able to get a great comparison in the first clean pull (35psi) with the divided setup, and didn't have to ponder if the 50mm gate changed boost holding at rpm when looking at the slightly different boost curves. We could infer that it was v-band setup itself when using the same wastegates/springs/etc. Also lines up with the lower EMAP reading up there, with less EMAP to influence the wastegate valve and subsequent boost level. Same thing with the small vs large, although the reason for the small reading less EMAP is a bit more perplexing.
