t3/t4 turbo questions
97 Talon Kid
89
Mar 21, 2005
Waterford, Michigan
Ok, i just bought a t3 turbo and i know i need a t4 mani, external wastegate, 255 fuel pump, 660cc injectors, fpr, 3" intake, hi flow fuel rail, oil feed/return lines and maby i'm missing a few things if anyone could infor me it would be appreciated and i also have a another question the hotside wheel has a i guess chunk carved outof it everything looks fine no shaft play but theres just a weird chunk missing right behind the nut i have a pic it's kindof blury but you get my point hopefuly.
WTF
That is how they balance the turbo. Exactly what turbo do you have? T3/T4 could mean 50 different combinations.
it says T04E and J84A on the turbo side not sure what that is it don't make sence to me.:confused:
Get some picture of both sides of the turbo. You'll have to remove the covers and measure the wheels to determine what turbo it is.
OK let me ask a really quick question. your title says T3/T4 turbo but you state you need a t4 manifold and in you pic it looks as if its a T4 turbo due to the V-band on the outlet for the turbine housing. my question is, are you sure you have a T3/T4 turbo or is it a T4 turbo. remember they are not the same thing nor is the manifold flange or the flow characteristics. this is a very expensive mistake when ordering parts or trying to get a setup correct.
sorry for the confusion i was stateing above that i know what some of the supporting modifications are needed also someone told me to take pics of the inducer so i took the comp houseing off and did so! The inducer measured 3 1/2 inches the hotside measued in at 3 inches so if someone could tell me the flow charicteristics on this t3/t4 that would be cool :thumb:
pics:
3' inlet
says t3/t4 t04e v-band also J84A?
exducer mesured at 3.5 inches
turbine exducer mesured 3 inches
Sorry i ment exducer on the comp wheel is 3.5" the exducer on the turbine wheel is 3";)
I'm not getting any replies to help me with this turbo i've searched and searched but all the threads are of topic to what i'm looking for:confused:
ok the comp wheel exducer is roughly 88.9mm give or take 00.1mm the inducer is roughly 72.4mm also give or take a few 00.1mm does that help any?:confused:
