T3/T4 setup help.
dsm nuff said
92
Sep 14, 2009
Montoursville, Pennsylvania
A buddy of mine is selling me his Precision T3/T4 Turbo. Not yet sure of the exact trim yet still waiting on that info. Anywho, what I want to know is, aside from internals, what's needed to run this kind of Turbo. I know ill need a manifold, o2 housing, external wastegate. What else is needed as far as bolt on parts. I tried using search and fame up with nothing. Any info would be great.
To run a t3/t4 turbo you will need a new manifold, external wastegate and dumptube, downpipe, maybe a new oil drain, and new intercooler piping. Depending on the size of the turbo you probably will need a better intake manifold, throttle body, bottom end, and head. Don't forget about all your driveline parts too. The trans wont be able to handle a lot of power for long.
If the turbo has a vband out let you dont need an 02 housing.
Thank you that should be useful info. I know Ill need fuel system upgrades and tuning software and I'm working on that stuff. As far as bottom end, Im told stock 6bolt is good for up to 600hp. Im only going for 4ish. Not yet sure on the details of the turbo Im still waiting for my friend to get back to me.
