T-belt pulley tensioner pin dimension?
Logue
408
6
Sep 27, 2003
Tuckerton, New Jersey
I'm at work, I don't have the car in front of me. I would like to get the tool before I get home, save myself alot of driving.
I have a couple T-belt Eccentric Tensioner pulley's tools here. Does anyone have a Jayracing or OEM eccentric tensioner tool that they could measure the outer and inner diameter of the pins for me if they are bored. ha.
I have:
Inner Diameter of 15.09"mm
Outer Diameter of 20.86"mm
Thanks Guys,
What are you asking?The pin that holds the plunger down during install?Just use a small allen wrench or a nail.
He's talking about the the pulley tool.. what you rotate the tensioner pulley with.
I have the JR one, I can't measure it until I get home though :(
Yah, I was looking for the distance between the two holes on the eccentric pulley.
I just grab all the special tools I have laying around. I'll try them out when I get home and let you guys know what happens.
If not Jayracing will be getting a call. :)
Thanks for the help guys.
Thanks 99,
.424" is 10.78mm so all the tools I brought home were to large. I used the old 90 degree snap ring pliers. They worked a bit awkward thats all. I'll just pick up the tool sometime soon thanks.
I just made one yesterday. The center to center is .550 and I used .125 pins.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
