turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Well, i searched and didn't find anything except for some newbs brainless replies.
Has anyone had a tensioner go out and make a lot of random clacking noises?
What i thought was a rod bearing can't be heard anywhere while listening to the block and head with a stethescope. The more i hone in on the sound is seems to be coming from teh T-belt area. Like i said before if i rev it up the noise goes away, but when it's atidle it's a very strange random noise.
I've worked on tons of motorcycles and cam chain tensioners are always failineg (especially on hondas) and this noise reminds me a lot of that noise. My t-belt doen'st seem loose, but there is a spot between the cam gears where there's not much tension on it, but that could be due to the way the valve train is sitting for all i know.
Before i tear into the front of the motor i just wanted some input. Normally im on with my diagnosis, but it's such tedious work to pull the engine down to jsut the timing components that i'd rather hear a 2nd opinion before doing it.
This is why i kept hearing it both under the intake and down towards the waterpump area.
