nicknorth11
- 663
- 7
- Feb 9, 2005
Grand Blanc,
Michigan
I have a dual stage boost controller so I can run low boost in 1st and 2nd and then switch to high boost. I switch between the two via a switch on my dash. I have problems when switching from low to high while in gear and on the gas. (The boost doesn't go all the way up to 21 psi, which is my high setting). Is this normal?
Thanks
Thanks
