High Boost, Low RPM. Bad?
FlatlandZak
Jan 14, 2008
Muskego, Wisconsin
So, I've heard that it is bad if you run your car at a low RPM at high boost.
I'm talking about being in fifth gear, engine at around 2500 and lower, and flooring it making high boost.
I know people just don't normally do this, but let's just say someone does.
Is it bad for the engine/turbo?
High boost at low RPM can lead to compressor surge due to the low air consumption by the engine. Compressor surge is bad for the turbo. That does not always happen though. Just a possibility.
And it is entirely possible to do that. You just need a turbo that I would consider entirely undersized, like keeping a stock 13g on a stroker. :p
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
