High rpm with low compression piston?
SvarO
92
Aug 28, 2004
panama, Central America
Hi everyone,
I try to search this info, but couln't find it, am planning to rebuild my engine soon, I want to do the correct spec for my goals, high boost and high rpm lets say 8.5k rpm, thinking on 50 trim for that goal, not money for bigger turbo.
Should I get low compression forged piston (keeping stock 8.5) or get 9.0 compression piston (wiseco) for higher boost and high rpm?
my engine have 148k miles and not smog or issues, I really like this engine.
Hi everyone,
Well, till then that motor could go for another 30k. But talking about compression you can't go wrong between 8.5 or 9.0. I wouldn't go any higher then 9.0.
IMO, id go with 8.5 wiseco pistons.
valve train is the biggest part used when it comes to hitting that type of rpm a good set of kinggly springs and retainers you cant go wrong. upgraded valves and a big cam 272-280 i prefer FP or kelford
as pistons go.. i would roll with either 8.3-8.8 wiseco or ross 9.0 not bad but you will prob want to run some high boost so you might want a added safety margin with the low CR pistons plus you will prob run more pump gas then anything and low CR piston come in handy then..
gl bro
I know i have to repalce my valvetrain a put some good cams there, that is a must, I was worry about the compression on the piston, so it doens't matter what you have on the bottom, you can just go high rpm....
i want this DD so no vp or meth here.. I just want to get the most power I can get on that setup under the safe spot.
then i would go with 9.0 because the low CR with effect the starting motion of the car(lag) is you will on acceleration during daily driving duties.. and since you want this to perform everyday that lag could become bother some to you.
and i don't think to many performance companies make pistons in 8.5 size i think its either 8.3 or 9.0 at least wiseco is that way
also don't skimp on any parts either the first time around....gl
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
