Suspension Basics
djXternal
195
Aug 30, 2004
Wesley Chapel, Florida
Hey... well I want to lower my 99 eclipse GS A little, 1.5ish would be good... this is mainly for looks, but for handling as well
I've been browsing through the forums, and prior to doing this i thought all i'd need was lowering springs, but then i've run across camber kits, coilovers, shocks, etc...
could someone tell me what it is I'd need for optimal handling, and lowering capabilities and keeping it decently priced?
it all depends on the drop kit. if you do just springs and your camber looks to negative you will need a camber kit. its hard to say if you will need a camber kit but 9 times out of ten you will in order to keep the tires level. my buddy dropped his and never got around to a camber kit and his tires wore at an aggressive angle it was like half the tread was on the ground
drop springs and a camber will be fine and will cause normal tire wear after an alignment
since these cars don't have adjustable front camber you will most likely need a drop kit in the front especially if you are just doing it for looks. but for racing negative camber all the way makes a big difference
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
