Spyder Stuttering/Skip/Misfire
Furiyous
22
Mar 1, 2026
Tampa, Florida
So, I have been trying to figure out the issue with my car for the last couple months (1997 GS-T Spyder). For some reason, after i start the car anywhere between 5-20 minutes (its random) it starts to skip/stutter like it has a slight misfire of some sort. The longer its running, the more it will start to misfire and skip. It has never stalled because of it though.
When initially start the car from a cold start, it runs PERFECTLY, no skip, no issues. After usually about 10 mins or so of driving/idling and the car warming up, it starts doing this, at idle, acceleration, doesn't matter. Its almost like a random irregular heart beat at idle in a split second.
Things I have done so far:
- 4 new Spark Plugs, NGK, with proper gap (0.28-0.31)
- 4 new Denso Spark plug wires
- New ICM/PTU, original Mitsubishi part
- 2 new Delphi coils installed as well
- New upstream Denso O2 sensor (was insane to get this thing out of the manifold from how stuck it was)
I will say it has been much better with those things replaced but its still there, especially on acceleration. Even very light acceleration it will skip badly. I do not know what else to check for. My OBD tool won't recognize the car for some reason (i think the car is too old for my ThinkDiag scan tool) so I cannot tell which cylinder is misfiring. I did check the cigarette lighter fuse, and its good (this controls OBD II power/communication I guess from what I have read).
From what I have researched, could possibly be injectors, injector resistor pack, ECT Sensor, Cam/Crank Position Sensors, vacuum leak or worst case the ECU. Engine Temperature gauge goes up to normal operation and stays there right below the halfway point so I am not sure its the ECT Sensor.
There is NO CEL that comes on at all, even when it skips, so I have no clue where else to look. I even unplugged the upstream O2 sensor to keep the car in open loop and still occurs. Any ideas would be helpful. My dad is going to try to bring his scan tool from work to check and see if it will communicate with the car so I can get a reading on the misfires hopefully some time this week.
Anything I miss? Should I check anything else while I wait for a scan tool?
Thanks for any input.
Do you see the CEL for a few seconds after turning on the ignition? Maybe there's a code stored you haven't noticed, so definitely check for that when you get a working scantool.
How are your electrical grounds? Starter bolt, firewall, intake manifold, and neg battery post grounds should be tight and clean.
Haven't checked the grounds yet, but will do that. I did also replace both the terminals for the battery connections as they were all corroded and worn out. I do not recall seeing the check engine light come on at the start, ill keep an eye on that. I did see it come on when i disconnected the O2 sensor so i know the light is working.
I am more concerned that it has no communication from the OBD II. I noticed a lot of threads on here for that happening for multiple reasons. Is there another fuse besides the footwell cigarette lighter that can cause communication issues with OBD II port in case I have the same issue with another scan tool?
Yes. The kick panel 10 amp Door Lock fuse (middle row 2nd from right) which provides power to the OBD pin 16 connector.
Your starting problem sounds like the classic "Hot start" (aka vapor lock) problem. Usually it's the fuel pressure solenoid (https://www.dsmtuners.com/threads/vapor-lock-hot-start.217349/#post-1821514). It's on the firewall between the brake fluid reservoir and the clutch reservoir.
Thanks for that thread. I did check and read through that, mine doesn't have an issue starting after warming up. It starts up every time just fine with no issue. Its just skipping/hesitating. Like as if a spark plug was bad or not getting enough fuel
I did manage to get the scan tool hooked up, no codes stored except the O2 Sensor code when I unplugged the front O2 sensor, no codes generated during the skipping. MAF readings were within range. ECT showed consistent temperature and not jumping around. It did not show me which cylinder was misfiring though. Not sure if its the scan tool or just that the car is too old for it to give that kind of data. It would show up as misfire being detected but didn't give more info than that. Not a single CEL light at all even during the skip.
My dad thinks it seems like its fuel related and leaning towards clogged fuel filter, bad injector(s) or failing fuel pump.
I did check the grounds, and all those looked good with no issues.
I think I am going to start with replacing the fuel filter and see what happens. I don't think its ever been replaced, maybe once.
Sorry hadn't made any update to this in a bit.
My dad and I went to work on the fuel pump and filter and the fuel lines to the bottom of the filter and to the top of the pump hangar are so stuck they wont budge. When we tried to take the lines off, it was bending the metal line on the hangar. So we haven't been able to replace them and test to see if the issue is resolved.
Hoping to get it done in the next couple weeks. Slowly been using PB blaster on the lines to help loosen them, but I fear I may end up needing to replace the hangar and/or the line itself if it breaks.
Take the line off below the car and remove the fuel pump hanger, metal line and rubber line all as one. The rubber line isn't very long.
Not sure if you're using one of these but I had to use a brake line wrench on mine. I even had to wrap some electrical tape around it to make it even tighter on the wrench to keep it from stripping.
On the fuel filter use a flare nut wrench on tube holding bolt/nut and another (or open end) on the filter can nut next to it if there is one (if there isn't another one on top, look on bottom - see pics). This is after spraying with PB Blaster, tapping with a hammer, and sitting for an hour, repeat, repeat. If all else fails you can try a locking pliers on the bottom soft tube nut but know that it will damage/crush it because it's a soft pot metal - but if you've got nothing to loose at that point anyway where your next step would be replacing the line...
Thank you for this. This was very helpful and helped get the line off.
We did get the fuel filter and pump finally replaced and the skip was much better. But still there.
I ended up also replacing my alternator as it was bad. After replacing that, skip was gone. Never thought that would have been the cause for it.
However, then it came back very mildly like a couple weeks later but it was random. And now I noticed this happening and I believe that it might be causing the new skip.
I ordered a new thermostat housing, radiator, thermostat, radiator cap, upper and lower hoses, and the ECT sensor with the Conmector as it’s probably corroded.
So that’s my new project to do this coming weekend along with a new AC compressor, accumulator/drier and new expansion valve. AC works fine it’s just an old compressor and I want to replace it since it’s 30 years old and gonna probably give out at any moment 😂
Why don't you datalog it and find out what ECU is doing? coolant temp, fuel trims, throttle position, o2 sensors etc.
My 99 Gst had similar issues when the throttle position sensor was out of whack and needed to be calibrated. When it got warm it couldn’t sense the throttle closed position accurately. It would miss fire under light throttle and buck and hesitate, when it had that problem I could floor it and the misfire would clear up
If possible monitor your throttle position sensor values in live data, there also could be a vacuum leak with the biss screw causing a high idle
