Stuttering problem
boostnbuds
107
Feb 19, 2004
Warren, Rhode Island
I have the most annoying problem in the world and i cant figure it out. When i spool boost 12 lbs or more my car does this stutter thing and the power isnt there after it happens you can usually smell the lovely sulfur smell from the cat. It doesnt usually do it unless i go more than 60% into the throttle. I dont know what it is some one has got to be able to help me out. I've got no vaccum leaks i have replaced the fuel filter made sure my plugs were clean and gapped i changed the tps sensor and removed the throttle body and cleaned it out real good. i have a new intake and filter i have also run a fuel injection cleaning. i removed the whole intake system and inspected for boost leaks on the clamps... so i've got nothing i need more ideas
For anyone who may have the strange throttle related stutter...I had tested everything checked everything and cleaned everything and it turns out no matter how clean and well gapped your spark plugs are they not be 100% my platinums were only 6-8 months old and apparently that was my problem what a kick in the balls :tease: :cry:
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
