ongoing stuttering problem....
awddsm95
96
May 2, 2004
Uniontown, Ohio
I have a 95 tsi awd with a dejon intake, Br upic w/1g bov, safc2, 2.5 turbo back, running around 14psi. I have had a studdering problem and backfire sound through the exhaust for a while now, and ive been chasing it ever since it started. new plugs ngk bpr7es and msd 8.5 wires, new fuel filter.... still studders, sometimes its worse than others, sometimes is completly gone. i though that it was wiring going to ecu, but it seems that its just a coincidece. problem happened before safc install and still occurs, the only thing that dosent make since is that if it were wiring, i would be throwing a code if a sensor was bad or i had a short going to the ecu, plus, it would either be making the connection or not, u cant really half ass it. If it were mechanical, such as a burnt valve, its would be all the time, unless it was a sticking valve, which may have been caused by my stupidness of putting straight 50wt oil in for about 2000 miles until i realized that was dumb and switched back to 5w30. i would figure that it would not be sticking anymore if with the lighter oil lubing it. Buschur told me fuel, but im on stock turbo... fuel cut is unlikely, but i did hear my pump making clicking noises when i was sitting still at a stop. If my pump is going bad, or is bad, would this be causeing the stutter, and or would it be all the time or intermintent like it is for me.... Im so tired of this and it needs to be ready for the dsm shootout on the 15th. Im planning on putting in a 190 pump and haveing the fuel system cleaned at a shop. with the 190, everything be ok, or am i going to need a afpr? Thanks for the help, my problem is almost solved.
I had the same problem, except it got soo bad that the car would not start. I replaced everything I could think of from plugs to ecu to MAF sensor.
The last thing I could think of was the crank angle sensor was bad. I wired in a 1G CAS and wouldn't you know I all went away.
Try it and see if it helps
Later
Nick
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
