stock
Mitsuboy1986
Feb 14, 2006
robbins, North Carolina
these qustions may seem a little dumb but what is the stock wheel size and boost on the 2cd gen gs-t/gs-x ? also has any body out there sone a gs-x conversion to their gs. i read about one in the knew super streeet and it was kinda funnny because i was with my friend and i had just got done telling him that eclipses or dsm's never get put in there. its alaway F-N hondas. every once in a while they throw an evo in there. asny way enough of my rant
Stock wheels are 16" except for 97-99 GSX, and 97-98 Talon AWDs, which got 17s. Stock boost is around 10psi. As far as the conversion, I don't know, but for what you'll spend on it you could pick up a stock factory-AWD car.
Well having done a couple of conversions spyder to AWD, and GST to GSX, about 2K in labor plus parts. Also you will need quite a few parts, your best bet is to find a donor car.
In my opinion converting a GST to a GSX is not worth it, since you can sell the GST, and then go buy a GSX. You will spend less this way. Converting a spyder to awd is the only way to have a awd spyder, unless you buy one already converted.
Wow i didnt know spyders were never factory made GsX's...thats really strange? But isnt converting a Gs to Gs-X all about tranny and axels? correct me if im wrong ### id like to know more
OK, you're wrong. ;) A GS model has a different engine if it is a 2nd gen with opposite motor mounts etc. Just converting one of those to a GS-T is murder.
Swapping to a GSX requires a new fuel tank, rear-end assembly, second job, and girlfriend when she dumps you for spending all your time working on the conversion.
But then you can date your car and all will be right with the world. It wont freak out on you for no reason.
Are you sure you own a DSM? ROFL
Sorry, no more thread theft.
Don't do the swap, just go buy a GSX and be done with it or be happy with your GST
yeah thats what i want is a like a 98 gsx :rocks: i already have a 4g63 j-spec i plan to do the turbo and engine work on it while i still have it on the stand. i was just checking to see how much of a pain thin the @$$ it was to do it. ROFL :dsm:
however i know you can get teh same performance value out of a gs-t but isintthe gs-x always quicker through the 1/4
I take it you'll be doing a six-bold JDM swap then? (We DSM'ers use JDM, not j-spec, that's a Honda thing ;) ) If it is a six bolt, have you done your research on the swap? That isn't a drop-in job either... unless you actually just drop it in and don't want it to turn the wheels...
I wish I'd done some work on my JDM block before stuffing it in. Should've replaced all the seals/gaskets on it. It's leaking oil like a sive right now. :cry:
( the j-spec thing was the search i did to find the motor) yeah its a six bolt. my plan is to put some stronger cams in it and i do plan to replace the gaskets a guy around here with a prelude bought a j-spec motor and it did the same thing leaked oil. yeah i did a litle research don't i need the same transmission for the year of the 6 bolt ? also i have teh chance to buy a gs-t spyder the wieght difference is only 121 pounds thats like racing seats and a carbon fiber hood to equal out the weight i dont really like convertibles but i want that performace so i just really want to wait till i can pick a gs-x
