Stock fuel, stock ic/pipes 14b record
There is not really much you can do with the stock fuel pump. I hit a 13.3 with the stock injectors, lines, intercooler & piping and exhaust.
hey guys, i was going to install an FP big 28turbo, and i was wondering if i could get by with just 550 injectors and a new fuel pump,:rolleyes: just somthing to make the car run right with the turbo. and yes i do have the SAFC to adjust em. thankks ?????
Come on:beatentodeath:
I know Phil Beers went 12.0 many years ago on the stock injectors/IC.
Wow, great memory!
[email protected]
Had walbro pump only. Stock FPR, 1G MAF, etc.
Went to 12.49@107 with stock pump and then decided it was better to be safe than sorry and upgraded the pump.
Phil
I enjoyed the read. At what point did you have to cut the divider wall on the 1G MAS? I wish it was easy to get ahold of good 14b turbos. Theres no way of making a 14b with a 16g is there? I always wanted to shoot for that record.
I'm not sure that I had to remove that wall, but it's easy to see why there are benefits to doing so. I'm fairly certain that particular mod came as a recommendation from another 14b guy at the time, Greg Horn, who had gone 12.4@110 when only Doug Derby and Jeff Carpenter had hit 12.2-3.
In a nutshell....warding off fuel cut is one reason for this mod, as I had a stock non-eprom ecu,and easier airflow to the engine. I went to the 2G MAF years ago and have run my original 1G MAF in two other DSM's and it worked great. A streetgoing 14B DSM needs nothing more than this in my opinion, granted 2G MAFs are fairly cheap and easy to install.
Phil:talon:
It would seem to me that trying to set any record with the stock fuel pump is just asking to blow up the motor.
I was able to go 11.9 @ 111 on a 14b with a stock sidemount, but it was on 550s and a walbro pump.
