Stock Boost [Merged 5-7]
Gs-tHaVoC
65
Mar 19, 2002
hehe kinda dumb question but whats stock boost on my car? just wondering if its worth it to install a boost controller and gauge without bov thats all. thanx
So how do I remedey this, what free mods do you recomend?
I have removed my upper and lower honeycomb already...
if it is sticky, it may be from the inside of the turbo. That will require the turbo to be taken apart.
If it is the arm, yea lube it up.
You can run a hose straight from the output nipple on the turbo to the wastegate actuator. Make sure you zap-strap it on both ends. And block off the other open hoses/nipples. Dont let anything get caught in the fan(s). when you do this, you will see 10psi or so max, as this is what the wastegate actuator is set at. I find the throttle response really crappy like this tho, as boost will slightly open it earlier than we are used to with a manual boost controller, but you will know if you can at least get 10psi.
Originally posted by larryd
Stock level is 11.x, very close to 12 on a 2g.
everyone has told me that 9 is the stock psi on a 2g but i guess they are wrong:confused: i am confused:(
yo guys not be a dick to the kid he just wanted a quick reply not smide remarks, the answer to your question is this, stock it will run at about 10-11 psi , if you wanna turn it up " I " say go no higher than 15psi, that is a safe range, and that stock 1g bov is good for it
Bill N @ www.extremetuners.com
I'll tell you what. How about YOU sit here an answer the same question over and over again. I think that question shows laziness and lack of effort. Its very annoying.
